> Shall I say... 3.6?, my conversion thread ...
post Jan 21 2006, 10:19 PM
Resident German
alright, time to start a conversion thread. i picked up the engine a month ago and started with the prepping of the tub today.
didn't get too much stuff done, oh well, babysteps ...
the ToDo-List (striked-out items are done!):
i'm going to overhaul the suspension, mount a front oil cooler with fan(s), fix a few spots on the tub the PO had hacked together, add racing seats and 5-point harness, install the 944 axles, the 911 eBrake, the new trailing arms, add a rear sway bar, Mueller roller bearings, new 250lbs springs on adjustable perches, fix the front sway bar, install new rear window, fix the gastank (correctly this time), replace the plastic fuel lines, get a trick porsche motorsports setup for my oiltank, add a vent to the front hood, redo the rear spoiler (ducktail), 100mm wheel studs all around, throw in the 3.6L motor and when all that is done, i'm going to give her a one of a kind paintjob!
oh, and i'm still playing with the idea to have her put on a celette bench to make sure she's straight ...
ETA: soon enough to run a full season for 2006 2007 !!! (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/aktion035.gif)
UPDATE: current todo list can be found HERE: todo list as of 04/25/07
This post has been edited by SirAndy: Jun 4 2012, 12:04 PM
Trekkor
post Feb 4 2006, 11:31 PM
I do things...
I almost popped by... (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif)
KT
SirAndy   Shall I say... 3.6?   Jan 21 2006, 10:19 PM
SirAndy   the motor, 3.6L '95 993 Twin Plug   Jan 21 2006, 10:40 PM
Joe Sharp   http://www.914world.com/bbs2/html/e...   Jan 21 2006, 10:46 PM
trekkor   This will be a fun ride. I like what you are doin...   Jan 21 2006, 11:00 PM
Travis Neff   http://www.914world.com/bbs2...   Jan 22 2006, 12:37 AM
alpha434   Did the engine come with the dual 6 distributer se...   Jan 22 2006, 01:08 AM
SirAndy   ...   Jan 22 2006, 02:07 AM
Scott Carlberg   <...   Jan 22 2006, 02:14 AM
SirAndy     Jan 22 2006, 06:29 AM
9146986   You are gonna LOVE that engine in a 914!!...   Jan 22 2006, 07:58 AM
seanery   Andy, I'm excited for you and jealous all at t...   Jan 22 2006, 09:49 AM
SirAndy     Jan 22 2006, 11:47 AM
Eric Taylor     Jan 22 2006, 01:02 PM
trekkor   You better get to work! ( I always wanted to s...   Jan 22 2006, 01:14 PM
SirAndy   <...   Jan 22 2006, 10:42 PM
SirAndy   underside, prepped for mounting bracket:   Jan 22 2006, 10:42 PM
SirAndy   trunk support plate welded in:   Jan 22 2006, 10:43 PM
Howard   Hey Trek, if Andy gets a car that's fast enoug...   Jan 22 2006, 10:44 PM
SirAndy   mounting bracket welded in:   Jan 22 2006, 10:44 PM
SirAndy   McMark welding ... http://w...   Jan 22 2006, 10:45 PM
Howard   Seriously, that is a winner!   Jan 22 2006, 10:45 PM
SirAndy   after metal ready and primer ...   Jan 22 2006, 10:46 PM
SirAndy   i also replaced my old 180lbs progressive springs ...   Jan 22 2006, 10:48 PM
SirAndy   and here's the new stuff, bling bling ...   Jan 22 2006, 10:50 PM
Scott Carlberg   DAMN Andy, er, SirAndy, planning on going to th...   Jan 22 2006, 10:50 PM
SirAndy   we had some fitting problems on the bilstein shock...   Jan 22 2006, 10:56 PM
SirAndy   this shows how much of the top rubber needs to be ...   Jan 22 2006, 10:57 PM
SirAndy   here you can see the part of the top mounting piec...   Jan 22 2006, 10:58 PM
SirAndy   and done (sans the top rubber):   Jan 22 2006, 10:59 PM
SirAndy   perfect fit! http://www....   Jan 22 2006, 11:00 PM
redshift   Screw all that! Let's see it go!!...   Jan 22 2006, 11:00 PM
SirAndy   artsy shot of mark posing ... http://www.914world.com/bbs2/htm...   Jan 22 2006, 11:03 PM
SirAndy   last for today, butt shot after adjusting the ride...   Jan 22 2006, 11:05 PM
SirAndy     Jan 22 2006, 11:08 PM
rick 918-S   http://www.914world.com/bbs2/...   Jan 22 2006, 11:36 PM
Root_Werks   http://www.914world.com/bbs2/...   Jan 23 2006, 10:29 AM
SirAndy   some more babysteps today ... mark and i scratche...   Jan 28 2006, 11:07 PM
SirAndy   one more ...   Jan 28 2006, 11:07 PM
SirAndy   we also made a cardboard mockup of the oil-cooler ...   Jan 28 2006, 11:10 PM
SirAndy   hopefully, by next weekend, i'll have the cool...   Jan 28 2006, 11:12 PM
Aaron Cox   i have similat bilsein coilover issues. looks like...   Jan 28 2006, 11:22 PM
Jeroen   I just remembered I promised to measure that front...   Jan 28 2006, 11:32 PM
SirAndy   here's a link to a HUGE jpg (1:1 scale) of the...   Jan 29 2006, 12:22 AM
seanery   Have a real hot rod guy do your louvres, they know...   Jan 29 2006, 12:42 AM
SirAndy   <...   Jan 29 2006, 12:53 AM
0396   Andy, CONGRATS! http://www.914...   Jan 29 2006, 08:43 AM
SirAndy   more "babysteps" ... got off to a slow start, did...   Feb 4 2006, 11:03 PM
SirAndy   took like 2 hours to get the two sides separated ....   Feb 4 2006, 11:04 PM
SirAndy   mark convinced me those would be much nicer all cl...   Feb 4 2006, 11:05 PM
SirAndy   and then some primer, so they don't turn into ...   Feb 4 2006, 11:08 PM
SirAndy   time for some http://www.914w...   Feb 4 2006, 11:08 PM
Aaron Cox   tell us about your hood louvers.   Feb 4 2006, 11:09 PM
SirAndy   ...   Feb 4 2006, 11:12 PM
Aaron Cox   curious in your method... cut 3x, fold 2x..... ...   Feb 4 2006, 11:13 PM
SirAndy   ...   Feb 4 2006, 11:26 PM
trekkor   I almost popped by... http:/...   Feb 4 2006, 11:31 PM
SirAndy     Feb 5 2006, 01:16 PM
jonwatts   I like the louver idea, but your air funnel looks ...   Feb 6 2006, 09:44 AM
SirAndy   ok, here's a small JPG of the oil-cooler shrou...   Feb 7 2006, 03:36 PM
Aaron Cox   have you thought about making the top / exit wider...   Feb 7 2006, 06:07 PM
ppickerell   Andy, I may be able to cut your shroud for you if ...   Feb 7 2006, 06:16 PM
McMark   ...   Feb 7 2006, 07:41 PM
SirAndy     Feb 7 2006, 09:05 PM
retrotech   I absolutely agree about dumping air under car, wh...   Feb 9 2006, 04:23 PM
SirAndy   more babysteps but no pictures today ... got the...   Feb 18 2006, 11:23 PM
pete-stevers   Andy what are you doing to the gear box? is it a 9...   Feb 19 2006, 12:19 AM
SirAndy   http://www.914w...   Mar 21 2006, 08:18 PM
SirAndy   here's why my project has been kind of on hold...   Apr 9 2006, 05:06 PM
jd74914   That sucks Andy http://www.914worl...   Apr 9 2006, 05:41 PM
Leo Imperial   Andy, I gotta ask. When did you find out that your...   Apr 9 2006, 06:07 PM
SirAndy     Apr 9 2006, 07:36 PM
McMark   That's worse than I thought Andy.
24 User(s) are reading this topic (24 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 10:45 AM
