Oily Mess II, part deux ... |
SirAndy |
Sep 4 2004, 08:29 PM
Resident German Group: Admin Posts: 41,694 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
found the problem with the tranny ...
i'm going to puke now, then probably half an hour of this: (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) more later ... |
SirAndy |
Feb 8 2006, 11:32 AM
that's the main bearing(s) spinning in the case ... when the shaft is unsupported in the front, it "wobbles". that causes the main bearings to work themselves lose in the case. they can't go anywhere (back/forth) but they will spin in the case. that's the noise you get. it will get worse over time, causing the shaft to wobble under load, even if you now have the pilot bearing in the front ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
Lo-Fi Version | Time is now: 20th June 2024 - 05:57 AM |
