914zim |
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 ![]() |
Now that I got your attention... (IMG:style_emoticons/default/laugh.gif)
I noticed that my rear brake calipers have both an upper and a lower bleed nipple like the fronts. Does this mean a PO put front calipers on the rear? I also noticed the P-brake isn't connected either, which I think is another indication. I am going to order the rebuild kits, but I want to know if I should order 4 front kits. Where should I get the kits from and how much are they? Any info is appreciated... Andy... (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
He needs to check and see if the lever arm is on the bottom of the caliper for the Ebrake. If they have NO arm.. then the PO put fronts on the rear.
B |
Lo-Fi Version | Time is now: 7th July 2024 - 07:35 AM |
