machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
need to setup the car.
thinking about -2 deg camber front and rear with 1/16 toe out to help turn in and standard castor setting. Is this a good place to start? thanks, david (IMG:style_emoticons/default/driving.gif) |
machina |
brad,
I understand about cutting the shock tower sheet metal towards the inside. Did you mean that you also trim the upper strut mount? I didn't think that was required if you run the tarret or some other rigid mount. We are not permitted to run Hoosiers but Kumho VR are allowed. I think the Kumho's will like -2deg camber. david |
Lo-Fi Version | Time is now: 7th July 2024 - 07:01 AM |
