yarin |
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States ![]() |
The previous mechanics who worked on my car were smokin something silly. I keep finding the stupidest things on here. By the time I'm finished with this car it will be done the right way, no shortcuts or anything.
I pulled the fuel tank by myself without removing the hood. It was pretty easy. Just don't forget to remove the fuel fill tank and disconnect the tank level sender. I took a bunch of pics. It's pretty dirty down there. Tank looks good though. When some schmuck converted from FI to carbs they intentionally kinked and clamped the return line under the tank. They also shoved a bolt in the line at the engine side return. The fuel filter looks like the regular filter, except if u look closely the rubber lines are splitting at the ends. And now the mystery... As it turns out there are solid metal lines in the fuel tank side. In the front of the tunnel the lines are also metal. Under the shift the lines are plastic! Is this the stock configuration? Here are pics: Attached image(s) ![]() |
yarin |
fuel filter.
Lo-Fi Version | Time is now: 22nd February 2025 - 11:10 AM |
