> Fuel Line Replacement... in progress, Tank pulled... WEIRD!
yarin
post Feb 15 2006, 06:39 PM
'14-X'in FOOL
The previous mechanics who worked on my car were smokin something silly. I keep finding the stupidest things on here. By the time I'm finished with this car it will be done the right way, no shortcuts or anything.
I pulled the fuel tank by myself without removing the hood. It was pretty easy. Just don't forget to remove the fuel fill tank and disconnect the tank level sender. I took a bunch of pics. It's pretty dirty down there. Tank looks good though. When some schmuck converted from FI to carbs they intentionally kinked and clamped the return line under the tank. They also shoved a bolt in the line at the engine side return. The fuel filter looks like the regular filter, except if u look closely the rubber lines are splitting at the ends.
And now the mystery... As it turns out there are solid metal lines in the fuel tank side. In the front of the tunnel the lines are also metal. Under the shift the lines are plastic! Is this the stock configuration?
Here are pics:
Dave_Darling
post Feb 15 2006, 09:53 PM
914 Idiot
Check the pics in the "Tour of a Center Tunnel" tech article on the Bird site. You'll see how the stock lines go together.
http://www.pelicanparts.com/techarticles/9...nter_tunnel.htm
--DD
yarin   Fuel Line Replacement... in progress   Feb 15 2006, 06:39 PM
yarin   front tunnel.. still metal.   Feb 15 2006, 06:39 PM
yarin   under shifter... PLASTIC! http://www.914world.com/bbs2/ht...   Feb 15 2006, 06:42 PM
yarin   look no tank!   Feb 15 2006, 06:42 PM
yarin   fuel filter.   Feb 15 2006, 06:42 PM
McMark   That's the stock setup. http:/...   Feb 15 2006, 06:47 PM
yarin     Feb 15 2006, 06:49 PM
Travis Neff   Fuel lines in the the tunnel come stock like that.   Feb 15 2006, 06:52 PM
McMark   The metal is "bumpy"/serrated and the plastic is p...   Feb 15 2006, 06:52 PM
Dave_Darling   Check the pics in the "Tour of a Center Tunnel" te...   Feb 15 2006, 09:53 PM
mcbain77   My '70 1.7L lines are all plastic - no metal a...   Feb 16 2006, 12:19 AM
Huff   I am changing my fuel line and have pulled my tank...   Feb 16 2006, 10:32 AM
yarin
- Lo-Fi Version Time is now: 22nd February 2025 - 10:57 AM
