Going to the Runoffs, Upgrading my engine (pictures) |
ChrisFoley |
Aug 30 2003, 07:49 AM
I am Tangerine Racing Group: Members Posts: 7,960 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I want to make a good showing at my first SCCA National Runoffs so I decided to upgrade my backup engine. (I don't have a real race engine right now.) I'm installing my 94mm Nickies set
Attached image(s) |
ChrisFoley |
Sep 7 2003, 11:22 AM
QUOTE(Brad Roberts @ Sep 4 2003, 01:45 PM) Chris.. I may have a cam for you on the next engine (the cam) you could run the LN lifters against it and build out from there. Your new shift chip will be 8k and you will need much bigger cooler(s). The one you have now just barely cools our stock 2.0 engines. B Brad, I have a couple of Elgin cams designed just for my application. One of them works up to 8k. But, I'm open to suggestions. I did a little more head work on the milling machine. I like to use an aircraft CHT sensor which requires a special hole. Attached image(s) |
Lo-Fi Version | Time is now: 5th October 2024 - 02:35 PM |
