Drain the Tank, can it be done easily? |
johnmhudson111 |
Feb 16 2006, 12:30 PM
Member Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 |
I have a 1/2 tank of gas in the car and need to drain it. Is there an easy way to do this?
rhodyguy |
Feb 16 2006, 12:52 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,113 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
if it still has the fi, remove the supply line to the fi pump. borrow a facet pump, hook it up to the supply line @ the engine side firewall, put a long piece of hose on the outlet of the facet, hook the facet up to a bat with some wires and pump away. i've done the "drain it under the tank". if you don't have a gas can big enough, the fuel is going to spill every where when you are trying to change catch cans. the initial undo usually results in a bath. if you are running a facet or pump for carbs, just put a long piece of hose on the pump.
k |
Lo-Fi Version | Time is now: 25th June 2024 - 05:39 PM |
