cool windscreens, how do you make em |
usa4cheer |
Feb 16 2006, 06:35 PM
Newbie Group: Members Posts: 29 Joined: 16-February 06 From: richmond, va Member No.: 5,592 |
I am working on my grassroots motorsport challenge car and want to take the windshield out of my car and want to do the mini windscreen. How do you make it???
alpha434 |
Feb 17 2006, 12:27 AM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
1969 Porsche 914/6 - Technical specifications This record added before December 1995. Last modified 2005-11-10. bodywork Type 2S FHC Designer Number of doors 2 dimensions & weights Wheelbase 2450 mm 96.5 in Track front 1343 mm 52.9 in rear 1383 mm 54.4 in Length 3985 mm 156.9 in Width 1650 mm 65 in Height 1220 mm 48 in Length:wheelbase ratio 1.63 Ground clearance 128 mm 5 in Kerb weight 940 kg 2072 lb Weight distribution (Front) Fuel capacity 61.8 litres 13.6 UK Gal 16.3 US Gal aerodynamics Drag coefficient 0.450 Frontal Area Cx engine Code Manufacturer Porsche Type F-6 Dry sumped SOHC 12 valves total 2 valves per cylinder Main bearings 8 Construction light alloy block & head Bore × stroke 80.00mm × 66.00mm 3.15 in × 2.6 in Bore/Stroke ratio 1.21 Displacement 1991 cc (121.498 cu in) Unitary capacity 331.83 cc/cylinder Compression ratio 8.60:1 Fuel system 2 We carbs Aspiration Normal Compressor type N/A Intercooler None Catalytic Converter N Max. output (DIN) 111.5 PS (110.0 bhp) (82 kW) @5800 rpm Max. torque (DIN) 157.0 Nm (116 lbft) (16 kgm) @4200 rpm Maximum rpm 6500 rpm Coolant Air Specific output 55.2 bhp/litre 0.91 bhp/cu in Specific torque 78.85 Nm/litre |
Lo-Fi Version | Time is now: 20th June 2024 - 05:29 AM |
