DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
I know in the past everyone has discussed using M calipers on the front with stock 914-4 rears along with a T fitting in place of proportioning valve.
What if you were to use the M calipers and 914-4 fronts on the rear utilizing the proportioning valve. would this negate enough of the rear bias with the larger 914-4 front pistons to give good braking? Possibly utilizing a milder rear pad as well with a very aggressive front pad? What do you think....and no I don't care about the E brake. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Thanks |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
and like you mentioned, you can play with pad compunds, etc... rear venting clearances.....
try an adjustable P valve.... dude... the JFZ's were the shizzle... i fondled a set before. very coolstuff |
Lo-Fi Version | Time is now: 26th June 2024 - 01:37 PM |
