DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
I know in the past everyone has discussed using M calipers on the front with stock 914-4 rears along with a T fitting in place of proportioning valve.
What if you were to use the M calipers and 914-4 fronts on the rear utilizing the proportioning valve. would this negate enough of the rear bias with the larger 914-4 front pistons to give good braking? Possibly utilizing a milder rear pad as well with a very aggressive front pad? What do you think....and no I don't care about the E brake. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Thanks |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
You can play around with some of the M calipers. There is quite a range actually. The 914/4 front is 42mm pistons, and the early fronts are very close to the 911 rear caliper. The 911 early rear and the 914/6 rear are both 38mm pistons. The late 911 rear is (I think the early 914/4 front) and has the 42mm pistons. Not sure if the late 914/4 front will fit on the rear without a spacing issue. Of course the 914/4 rear has the 33mm pistons. With a bit of work you could also use the 911 / 914/6 front on the rear with 48mm pistons.
So you have the range of 33mm to 48mm, and you will surely require something to limit the braking power of the rear. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:35 PM |
