> front brakes, best 4 lug set up
sk8kat1
post Feb 18 2006, 09:58 PM
I right now have the19 mm MC , SS brake lines and bmw front caliper upgrade from PO
I have heard the the stockers are just as good if working properly .. is this true ... is there a better setup than both and keeping the 4 lug ..
DanT
post Feb 18 2006, 10:28 PM
Going back to the Dark Side!
The billet hubs are the only way you can run the SC vented rotors.
The hubs mimic the function and look of 911 hubs. This way you can buy just rotors instead of your current rotor/hub combination. With the billet hubs you don't have to buy change bearings etc when you need new rotors.
Otherwise what would be the point of putting a larger caliper and generating more heat with no improved way of dissipating that heat?
Why add M calipers and keep solid rotors.
What is your obsession with thinking that the hubs are something comical?
sk8kat1   front brakes   Feb 18 2006, 09:58 PM
Dan (Almaden Valley)   Magical Billet hubs, M calipers and vented SC roto...   Feb 18 2006, 10:01 PM
sk8kat1   billet hubs -- are those the muller ones? how muc...   Feb 18 2006, 10:08 PM
Aaron Cox   <...   Feb 18 2006, 10:14 PM
sk8kat1   oooo.. http://www.914world.c...   Feb 18 2006, 10:17 PM
Dan (Almaden Valley)   No funny http://www.914world.com/bb...   Feb 18 2006, 10:18 PM
sk8kat1   are the muller hubs nessiary or just for the grin...   Feb 18 2006, 10:20 PM
Aaron Cox   <...   Feb 18 2006, 10:25 PM
Dan (Almaden Valley)   The billet hubs are the only way you can run the S...   Feb 18 2006, 10:28 PM
Aaron Cox     Feb 21 2006, 11:52 AM
Eric_Shea
  Feb 21 2006, 11:56 AM
Aaron Cox   koni's go hand in hand with shorter springs or...   Feb 21 2006, 12:08 PM
Eric_Shea   Shocks don't raise your ride height...   Feb 21 2006, 01:15 PM
sk8kat1   plan is this... my orginal plan was a mcmark 2056....   Feb 21 2006, 01:26 PM
sk8kat1   I was told that adding red konis would jack up the...   Feb 21 2006, 01:29 PM
Eric_Shea
  Feb 21 2006, 03:17 PM
tat2dphreak   IMO, if you don't have 200 HP, you only need s...   Feb 21 2006, 03:26 PM
sk8kat1   the rear shocks are orange no markings other than ...   Feb 21 2006, 03:42 PM
Eric_Shea
  Feb 21 2006, 03:54 PM
SGB   Hard bushings will shake parts off of both you and...   Feb 21 2006, 04:02 PM
sk8kat1   what is the differance between koni yellows and re...   Feb 21 2006, 05:21 PM
Mueller   <...   Feb 21 2006, 05:28 PM
sk8kat1   are the yellows the sport konis?   Feb 21 2006, 05:32 PM
sk8kat1   and what does it mean when they say a progressive...   Feb 21 2006, 05:37 PM
Travis Neff   Yellow's are sport valved Konis, adjust via kn...   Feb 21 2006, 05:48 PM
Mueller   koni yellows are sport...I think the reds are no l...   Feb 21 2006, 05:51 PM
jetboy   I see a bunch of comments about the stock brakes b...   Feb 21 2006, 06:46 PM
sk8kat1   where is the best place to get Porterfield street...   Feb 21 2006, 07:08 PM
lapuwali     Feb 21 2006, 07:14 PM
Mueller   <...   Feb 21 2006, 07:19 PM
jetboy   When i said spirited driving i meant fun runs thro...   Feb 21 2006, 08:10 PM
rdauenhauer   Ok Ill drop...
  Feb 21 2006, 08:24 PM
tat2dphreak   <...   Feb 21 2006, 08:40 PM
sk8kat1   so does that mean an adjustable proportioning valv...   Feb 21 2006, 08:54 PM
lapuwali     Feb 21 2006, 09:09 PM
sk8kat1   so with the pads should I replace bothe front and ...   Feb 21 2006, 10:52 PM
Eric_Shea
  Feb 21 2006, 11:00 PM
Eric_Shea
  Feb 21 2006, 11:02 PM
sk8kat1   http://www.914world.com/bbs2/ht...   Feb 22 2006, 08:45 AM
Eric_Shea   Needie aren't we? http://ww...   Feb 22 2006, 09:59 AM
sk8kat1   me needie... http://www.914world.co...   Feb 22 2006, 10:09 AM
Mueller   <...   Feb 22 2006, 10:11 AM
Eric_Shea
  Feb 22 2006, 10:24 AM
sk8kat1   had surgery stuck at home too much time to dream ...   Feb 22 2006, 10:30 AM
Eric_Shea
  Feb 22 2006, 10:59 AM
Aaron Cox   <...   Feb 22 2006, 05:16 PM
sk8kat1   suggested by eric shea...   Feb 22 2006, 05:21 PM
Eric_Shea
  Feb 22 2006, 05:48 PM
- Lo-Fi Version Time is now: 24th June 2024 - 07:10 AM
