Oil cooler..........round two, AKA fun with foam! |
East coaster |
Feb 17 2006, 07:56 PM
Senior Member Group: Members Posts: 1,791 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
So after a little brainstorming on an oil cooler layout, I figured I better actually do it.
Started out by figuring out the mounting of the cooler itself. It's a very large (4 x 24 fin area) and I think a good fit for a 3.6 since it doesn't have an engine mounted cooler. I started by cutting sections out of the front support tray for clearance and then re-boxing the area to keep the shelf rigid and serve as a mounting point for the front of the cooler. Here's a pic of the cut outs........... Attached image(s) |
drew365 |
Feb 19 2006, 09:37 AM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
Dave; do you think adding a scoop over the cowl vent with the opening facing the windshield, would create enough low pressure to vent out of the trunk? My cooler currently dumps the air under the car and I want to change that without cutting up my hood if possible. |
