Oil cooler..........round two, AKA fun with foam! |
East coaster |
Feb 17 2006, 07:56 PM
Senior Member Group: Members Posts: 1,791 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
So after a little brainstorming on an oil cooler layout, I figured I better actually do it.
Started out by figuring out the mounting of the cooler itself. It's a very large (4 x 24 fin area) and I think a good fit for a 3.6 since it doesn't have an engine mounted cooler. I started by cutting sections out of the front support tray for clearance and then re-boxing the area to keep the shelf rigid and serve as a mounting point for the front of the cooler. Here's a pic of the cut outs........... Attached image(s) |
mrdezyne |
Feb 21 2006, 11:34 AM
Now on larger rolling jack stands! Group: Members Posts: 468 Joined: 31-July 05 From: Tulsa, OK Member No.: 4,510 |
I was wondering the same thing. Looks like its directly on the foam since he had to cut away the core once it was cured. I've heard of wraping your core in aluminum foil and glassing on top of that before, just FYI... |
