yarin |
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States ![]() |
Like most people I'm not too thrilled with the design of the fuel rail system. I'm planning on buying 2 6" pieces of aluminum fuel rail and tapping it for 5/16" barbed fittings (3/8" NPT). I'm assuming that 3/8 NPT -> barb 5/16 exist. I found em.. on ebay
Does anyone know what the exact OD of the fuel injectors are? I'd like to use 5/16" high pressure fuel line on everything. I'm pretty sure I'll have to fab a bracket to support the extra weight of the fuel rail. I'm surprised the stock fuel rail is floating. I'll also tap a 1/8" NPT for the fuel pressure gauge. I've seen a fuel rail kit on the market, but it costs $170 or so. I can build this for ~$30. |
yarin |
Are you using the factory style bent injector hoses or straight fuel line? If its the latter i would imagine that could cause the flow restriction that you described. Cap'n... is 5/16" hose an acceptable size for the barb fitting on the injectors? |
Lo-Fi Version | Time is now: 26th June 2024 - 02:45 AM |
