Modern Injector and Higher Pressures, What improvements have you seen? |
Brian Mifsud |
Feb 21 2006, 07:43 PM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
Another thread about custom fuel rails had references to using modern high pressure injectors with associated proper manifolding.
Has anyone "converted" and how have your results been? I'm guessing you need to consider pulse voltage, pulse duration, flow rating of injector, and line pressure as the factors to pick the right injectors. Cleaner? Better driveability? Better mixture control? |
Lo-Fi Version | Time is now: 25th June 2024 - 06:45 PM |
