Racing rules make it hard to keep up, How do I cheat legally |
Joe Ricard |
Feb 22 2006, 09:01 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Ok now that I got you to open the thread.
as you all know I moved from SM-2 to X Prepared this year in SCCA SoloII. Street Mod was nearly any engine any size as long as it was Porsche. Prepared has a displacement rule of not over 1.4mm Bore increase. Guess that leaves the 96mm pistons back on the shelf. So how do I get more power ot of the racer. I am getting lighter with better wheels and stickier tires etc. Prepared has no limit on Compression ratio, valve size, ingition, induction, exhaust, piston must be metal and that's about it. Engine I was building was going to have 71 stroke 96mm chinese pistons in german cylinders hastings rings, 11lb flywheel, 6 puck solid clutch, 86b 86b +5 cam, 44 IDF's 2.0L ported heads with dual valve springs, Tangerine header. So I guess what I need if it exists is a 1.4mm bigger piston with hiddeous compression. |
groot |
Feb 22 2006, 09:09 AM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
Good luck with that piston.... Jake looked for some for my EP motor, custom jobs with huge expense. We settled on 95mm pistons, leaving that .4mm on the table.
Lo-Fi Version | Time is now: 12th November 2024 - 04:19 PM |
