Racing rules make it hard to keep up, How do I cheat legally |
Joe Ricard |
Feb 22 2006, 09:01 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Ok now that I got you to open the thread.
as you all know I moved from SM-2 to X Prepared this year in SCCA SoloII. Street Mod was nearly any engine any size as long as it was Porsche. Prepared has a displacement rule of not over 1.4mm Bore increase. Guess that leaves the 96mm pistons back on the shelf. So how do I get more power ot of the racer. I am getting lighter with better wheels and stickier tires etc. Prepared has no limit on Compression ratio, valve size, ingition, induction, exhaust, piston must be metal and that's about it. Engine I was building was going to have 71 stroke 96mm chinese pistons in german cylinders hastings rings, 11lb flywheel, 6 puck solid clutch, 86b 86b +5 cam, 44 IDF's 2.0L ported heads with dual valve springs, Tangerine header. So I guess what I need if it exists is a 1.4mm bigger piston with hiddeous compression. |
Joe Ricard |
Feb 22 2006, 12:16 PM
Yea SM-2 had funny rules that are subject to interpretation. the area of the car behind the seats of a street mod car can be gutted to the bare metal. yet must have full carpet (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) WHERE?
Street mod can have a carbon fiber engine lid. But I has to keep the steel trunk lids. (IMG:http://www.914world.com/bbs2/html/emoticons/bootyshake.gif) Stock as delivered 1970 Porsche 914 tipped the scales WAY less than the new minimum wieght of 2100 pounds for SM-2 mid engine RWD. |
Lo-Fi Version | Time is now: 12th November 2024 - 04:22 PM |
