OT: torsional rigidity in a u-shaped channel |
3liter914-6 |
Feb 19 2006, 10:24 AM
Master of Clueless Posts Group: Benefactors Posts: 310 Joined: 12-October 03 From: State College, PA Member No.: 1,238 Region Association: MidAtlantic Region |
Hello 914ers,
I've got a question that has to do with a Volvo project I'm working on. V8 conversion, and because I'm doing an efan and the engine is a little farther forward in the chassis than standard (due to the t56 tranny), I'm having some issues. The main issue is that I had to install the radiator 1" farther forward than standard. Not a huge problem, everything still fits, but the radiator is too tall and the cap extends above the slope of the fenders. When I get the hood back on, I'm going to have some problems. What I need to do is lower the top of the radiator crossmember. It's a U shaped channel, probably about 3" deep. 18 gauge steel, and with a stamped piece of 18 guage steel spot welded to the top of the channel to close it off. I figure to put the radiator in a position where the hood will close comfortably I need to chop about 1.5" out of the legs of the U. I bounced this off of a friend of mine who is an aero eng. grad student, and he confirmed what I thought--that the strenght of the crossmember is directly related to the height of the U. He couldn't answer my followup questions about whether seam welding and going with a thicker gauge of metal (16 or thicker vs 18) would make up for the lack of height. He did suggest that filling the enclosed crossmember with a heat expanding foam would add to the torsional rigidity, but didn't have any specific suggestions on products. IIRC a couple of manufacturers do this on their frame rails. Is anyone familiar with this technique, and where I can obtain such a product? Would one of those home insulation spray expanding foam product work (sprayed after all the welding is done obviously)? I have another question, which is related to cutting the 1.5" out. I'm not good at all with eyeballing a cut, and I can't get a ruler/t-square anything like that on there, as the crossember bows out in places, and I can't just measure up from the bottom as it's not a uniform depth. I've levelled the car off side to side, and will level it front to rear, so I was thinking I could lay some saran wrap in the channel, and fill it with something like plaster of paris. Something that'll pour in, and setup hard yet still be removable. Assuming I have everything levelled off, I should get a pretty straight and uniform line that I can use as a guide for my cutting. Sound reasonable? Any suggestions on a good material to use? Any other suggestions on getting an accurate cut? Thanks for any input/advice. Adam |
3liter914-6 |
Feb 22 2006, 12:37 PM
I've spent some time thinking about it, and I think I've got a plan worked out. I think the primary purpose of the piece is in fact just support of the radiator. After looking at the way it mounts to the frame rails, it just doesn't seem like it was built with bracing as its primary function. There are only 4 or so spotwelds mounting it to each rail. I have 2 thoughts on the project now. 1. is to drill out the spotwelds and replace the whole support completely. I was thinking I'd use 16 ga. vs 18 ga. There's one thing I'm uncertain of though. I don't have access to any real metaworking equipment, so I can't make the bends necessary to recreate the shape. I was thinking I could weld up a box of similar dimensions and weld it to the old mounting points. Would a welded box be weaker than a rounded piece of sheetmetal? 2. was similar, but instead of removing the crossmember, I would keep the stock mounting ears, and either weld in a fabricated boxed section as above or use the stock crossmember and use a thicker gauge metal as a bridge to drop the x-member the 2 or so inches that I need. I figured if I did a lap weld AND used spotwelds that it would be suitabily strong. Any thoughts on my current plan of action? Thanks! |
Lo-Fi Version | Time is now: 24th June 2024 - 07:39 AM |
