Racing rules make it hard to keep up, How do I cheat legally |
Joe Ricard |
Feb 22 2006, 09:01 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Ok now that I got you to open the thread.
as you all know I moved from SM-2 to X Prepared this year in SCCA SoloII. Street Mod was nearly any engine any size as long as it was Porsche. Prepared has a displacement rule of not over 1.4mm Bore increase. Guess that leaves the 96mm pistons back on the shelf. So how do I get more power ot of the racer. I am getting lighter with better wheels and stickier tires etc. Prepared has no limit on Compression ratio, valve size, ingition, induction, exhaust, piston must be metal and that's about it. Engine I was building was going to have 71 stroke 96mm chinese pistons in german cylinders hastings rings, 11lb flywheel, 6 puck solid clutch, 86b 86b +5 cam, 44 IDF's 2.0L ported heads with dual valve springs, Tangerine header. So I guess what I need if it exists is a 1.4mm bigger piston with hiddeous compression. |
alpha434 |
Feb 22 2006, 12:50 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
From an engineering standpoint, thats right. Billet won't help as much as reducing weight on the rotor, but the big advantage of biilet caps is the reduction of unsprung weight, and it could be enough to keep the unsprung weight the same when you go up to vented rotors. Unsrung weight is like 10 times as bad as extra weight on the chassis. That's why there's so much cashflow into carbon fiber and ceramic brake rotors now-a-days. On the other hand, pephaps the heavier rotor affects braking speed, since the extra mass affects the rotors tendency to stop or change directions. It would be nice to have some numbers. Hint hint. Anyone a rocket scientist? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 12th November 2024 - 04:20 PM |
