> Racing rules make it hard to keep up, How do I cheat legally
Joe Ricard
post Feb 22 2006, 09:01 AM
CUMONIWANNARACEU
Ok now that I got you to open the thread.
as you all know I moved from SM-2 to X Prepared this year in SCCA SoloII.
Street Mod was nearly any engine any size as long as it was Porsche.
Prepared has a displacement rule of not over 1.4mm Bore increase. Guess that leaves the 96mm pistons back on the shelf.
So how do I get more power ot of the racer. I am getting lighter with better wheels and stickier tires etc.
Prepared has no limit on Compression ratio, valve size, ingition, induction, exhaust, piston must be metal and that's about it.
Engine I was building was going to have 71 stroke 96mm chinese pistons in german cylinders hastings rings, 11lb flywheel, 6 puck solid clutch, 86b 86b +5 cam, 44 IDF's 2.0L ported heads with dual valve springs, Tangerine header.
So I guess what I need if it exists is a 1.4mm bigger piston with hiddeous compression.
Joe Ricard
post Feb 22 2006, 01:39 PM
CUMONIWANNARACEU
Turbos are for Street mod engines. But not Prepared.
WHich is OK cause the Stripper needs a .......... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Joe Ricard   Racing rules make it hard to keep up   Feb 22 2006, 09:01 AM
groot   Good luck with that piston.... Jake looked for som...   Feb 22 2006, 09:09 AM
Joe Ricard   Cool, so I'm not the only one to read the rule...   Feb 22 2006, 09:23 AM
DNHunt   Well I can tell you what not to do. Don't chan...   Feb 22 2006, 09:24 AM
URY914   I have a set of super rare 97mm p/c if you want to...   Feb 22 2006, 09:33 AM
brant   welcome to racing$$$$ So, I...   Feb 22 2006, 09:42 AM
jhadler   Hey Joe, I guess I'm not sure what you mean b...   Feb 22 2006, 11:27 AM
grantsfo   You can pull a whole lot of weight out of the car ...   Feb 22 2006, 11:45 AM
Aaron Cox   ...   Feb 22 2006, 11:48 AM
Joe Ricard   ...   Feb 22 2006, 12:00 PM
Richard Casto   <...   Feb 22 2006, 12:04 PM
Joe Ricard   You are correct sir. It looked like the results f...   Feb 22 2006, 12:10 PM
Richard Casto   ...   Feb 22 2006, 12:10 PM
Joe Ricard   Yea SM-2 had funny rules that are subject to inter...   Feb 22 2006, 12:16 PM
alpha434   ...   Feb 22 2006, 01:18 PM
Joe Ricard   I like to keep it simple. by that I mean rotating ...   Feb 22 2006, 01:20 PM
Brando   Hey Joe... Here's an idea... What do the rules...   Feb 22 2006, 01:35 PM
Joe Ricard   Turbos are for Street mod engines. But not Prepare...   Feb 22 2006, 01:39 PM
tommy914     Feb 22 2006, 02:42 PM
Jake Raby     Feb 22 2006, 02:53 PM
Joe Ricard   "those not so MAssIVe" ? h...   Feb 22 2006, 03:08 PM
URY914   Joe, Come down here and have a go in my car. Yo...   Feb 22 2006, 03:24 PM
Joe Ricard     Feb 22 2006, 03:32 PM
Jake Raby   Paul's engine is BADDER than the one that WAS ...   Feb 22 2006, 03:45 PM
URY914   <...   Feb 22 2006, 04:38 PM
Aaron Cox   shit... why not a carrera GT while were at it   Feb 22 2006, 04:39 PM
Joe Ricard   I would sorta feel bad about getting all red neck ...   Feb 22 2006, 08:57 PM
okieflyr   In "XP" your engine design or manufacture is open(...   Feb 22 2006, 09:43 PM
Joe Ricard   So putting 200 pounds back in your car wasn't ...   Feb 23 2006, 07:42 AM
okieflyr   Well the 200LBS wasn't an issue for me, as I...   Feb 23 2006, 08:20 PM
turboman808   Why exactly did they move you out of SM2? I haven...   Feb 23 2006, 08:31 PM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th November 2024 - 04:20 PM
