> Racing rules make it hard to keep up, How do I cheat legally
Joe Ricard
post Feb 22 2006, 09:01 AM
CUMONIWANNARACEU
Ok now that I got you to open the thread.
as you all know I moved from SM-2 to X Prepared this year in SCCA SoloII.
Street Mod was nearly any engine any size as long as it was Porsche.
Prepared has a displacement rule of not over 1.4mm Bore increase. Guess that leaves the 96mm pistons back on the shelf.
So how do I get more power ot of the racer. I am getting lighter with better wheels and stickier tires etc.
Prepared has no limit on Compression ratio, valve size, ingition, induction, exhaust, piston must be metal and that's about it.
Engine I was building was going to have 71 stroke 96mm chinese pistons in german cylinders hastings rings, 11lb flywheel, 6 puck solid clutch, 86b 86b +5 cam, 44 IDF's 2.0L ported heads with dual valve springs, Tangerine header.
So I guess what I need if it exists is a 1.4mm bigger piston with hiddeous compression.
Jake Raby
post Feb 22 2006, 02:53 PM
Engine Surgeon
Roll on the power is right.
Not everyone has RAt power, those not so MassIVe must hold the throttle WFO to have as much fun as you do at half throttle!
And that flywheel isn't even lightened!
Joe Ricard   Racing rules make it hard to keep up   Feb 22 2006, 09:01 AM
groot   Good luck with that piston.... Jake looked for som...   Feb 22 2006, 09:09 AM
Joe Ricard   Cool, so I'm not the only one to read the rule...   Feb 22 2006, 09:23 AM
DNHunt   Well I can tell you what not to do. Don't chan...   Feb 22 2006, 09:24 AM
URY914   I have a set of super rare 97mm p/c if you want to...   Feb 22 2006, 09:33 AM
brant   welcome to racing$$$$ So, I...   Feb 22 2006, 09:42 AM
jhadler   Hey Joe, I guess I'm not sure what you mean b...   Feb 22 2006, 11:27 AM
grantsfo   You can pull a whole lot of weight out of the car ...   Feb 22 2006, 11:45 AM
Aaron Cox   ...   Feb 22 2006, 11:48 AM
Joe Ricard   ...   Feb 22 2006, 12:00 PM
Richard Casto   <...   Feb 22 2006, 12:04 PM
Joe Ricard   You are correct sir. It looked like the results f...   Feb 22 2006, 12:10 PM
Richard Casto   ...   Feb 22 2006, 12:10 PM
Joe Ricard   Yea SM-2 had funny rules that are subject to inter...   Feb 22 2006, 12:16 PM
alpha434   ...   Feb 22 2006, 01:18 PM
Joe Ricard   I like to keep it simple. by that I mean rotating ...   Feb 22 2006, 01:20 PM
Brando   Hey Joe... Here's an idea... What do the rules...   Feb 22 2006, 01:35 PM
Joe Ricard   Turbos are for Street mod engines. But not Prepare...   Feb 22 2006, 01:39 PM
tommy914     Feb 22 2006, 02:42 PM
Jake Raby     Feb 22 2006, 02:53 PMJoe Ricard   "those not so MAssIVe" ? h...   Feb 22 2006, 03:08 PM
URY914   Joe, Come down here and have a go in my car. Yo...   Feb 22 2006, 03:24 PM
Joe Ricard     Feb 22 2006, 03:32 PM
Jake Raby   Paul's engine is BADDER than the one that WAS ...   Feb 22 2006, 03:45 PM
URY914   <...   Feb 22 2006, 04:38 PM
Aaron Cox   shit... why not a carrera GT while were at it   Feb 22 2006, 04:39 PM
Joe Ricard   I would sorta feel bad about getting all red neck ...   Feb 22 2006, 08:57 PM
okieflyr   In "XP" your engine design or manufacture is open(...   Feb 22 2006, 09:43 PM
Joe Ricard   So putting 200 pounds back in your car wasn't ...   Feb 23 2006, 07:42 AM
okieflyr   Well the 200LBS wasn't an issue for me, as I...   Feb 23 2006, 08:20 PM
turboman808   Why exactly did they move you out of SM2? I haven...   Feb 23 2006, 08:31 PM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th November 2024 - 04:20 PM
