Racing rules make it hard to keep up, How do I cheat legally |
Joe Ricard |
Feb 22 2006, 09:01 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Ok now that I got you to open the thread.
as you all know I moved from SM-2 to X Prepared this year in SCCA SoloII. Street Mod was nearly any engine any size as long as it was Porsche. Prepared has a displacement rule of not over 1.4mm Bore increase. Guess that leaves the 96mm pistons back on the shelf. So how do I get more power ot of the racer. I am getting lighter with better wheels and stickier tires etc. Prepared has no limit on Compression ratio, valve size, ingition, induction, exhaust, piston must be metal and that's about it. Engine I was building was going to have 71 stroke 96mm chinese pistons in german cylinders hastings rings, 11lb flywheel, 6 puck solid clutch, 86b 86b +5 cam, 44 IDF's 2.0L ported heads with dual valve springs, Tangerine header. So I guess what I need if it exists is a 1.4mm bigger piston with hiddeous compression. |
Aaron Cox |
Feb 22 2006, 04:39 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
shit... why not a carrera GT while were at it (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Lo-Fi Version | Time is now: 12th November 2024 - 04:22 PM |
