Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
A lot of newer cars do not have the traditional cable that goes from the gas pedal to the throttle body...instead the pedal has a potentiometer*, this in wired to the ECU which tells the throttle body how much to open, just because you have your foot buried to the floor, the throttle body might only be open 50% since the ECU is dictating what is going on.
Now a drive-by-wire throttle body could be wired directly to the pot. on the gas pedal to be 1:1 at all times......with a setup like this on dual carbs or individual throttle bodies, no need to worry about thermal expansion of motor and how that effects the linkage. * (similar to a variable resitor which varies the voltage output depending on foot placement) |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,359 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I don't think it would be allowed in most race groups. As a safety issue they like cables and return springs.
But you a street car it'd be cool. |
Lo-Fi Version | Time is now: 28th June 2024 - 08:42 PM |
