Drive-by-wire for dual carbs/throttle bodies???, would you run them?? |
Mueller |
Feb 28 2006, 03:42 PM
A lot of newer cars do not have the traditional cable that goes from the gas pedal to the throttle body...instead the pedal has a potentiometer*, this in wired to the ECU which tells the throttle body how much to open, just because you have your foot buried to the floor, the throttle body might only be open 50% since the ECU is dictating what is going on.
Now a drive-by-wire throttle body could be wired directly to the pot. on the gas pedal to be 1:1 at all times......with a setup like this on dual carbs or individual throttle bodies, no need to worry about thermal expansion of motor and how that effects the linkage. * (similar to a variable resitor which varies the voltage output depending on foot placement) |
r_towle |
Feb 28 2006, 03:58 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Sure would be a nice way to have hide away linkage on a beetle...
I like that clean look. I would say go for the weber market first...that has a larger installed base... I have a dual weber 40mm you could use as a test mule till summer...then the kid comes back... I think in the engine bay it would be fine...I would be very concerned putting sensitive electronics on the floor or either a beetle or a 914 considering the black hole effect that the floorboard area has in both cars... Rich |
Lo-Fi Version | Time is now: 26th June 2024 - 01:49 AM |
