mcbain77 |
Member ![]() ![]() Group: Members Posts: 155 Joined: 27-January 06 From: Houston, TX Member No.: 5,485 ![]() |
So i pulled the cylinder heads off a 1970 1.7L engine and they look really pretty . . . (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif)
This is my first Type IV to dismantle so does anyone have any suggestions? How does it look? I also took off the oil filler assembly and found 1/2" of rusted out gunk on the area below the breather assembly. How do i clean this out? Should I crack the case and just start from the beginning? Attached image(s) ![]() |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
You should buy a cam anyway. The one in there is wiped.
96 mm pistons and cylinders for 66mm stroke - $329 Cam - $180 Lifters $155 Balance rotating assembly - $120 I'd go with carbs on a cheapie motor - $400 All of the above is $1184. Then put as much money as you can into heads. You could throw a set of new guides in there and run it. But you're risking everything you spent on the possibility of a dropped seat. You'd have a sweet little 1911 motor. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) What's your budget? |
Lo-Fi Version | Time is now: 27th June 2024 - 08:37 AM |
