914 -engine sizes- fit/wont fit???, Technical HELLLlpPPP |
Boldylocks |
Sep 10 2003, 11:59 AM
Member Group: Members Posts: 120 Joined: 10-September 03 From: San Diego -CA- Member No.: 1,135 |
First, I'm the owner of a 73 914 with a 1.7 liter engine that has bent/broken intake valves. I'm not a mechanic, but the cost to repair this part seems to be as much, if not more, than finding a running engine and putting it into the car.
With that said: Can I 'drop' any 914 engine into the car??? 1.8 -2.0?? Is the mechanic correct, will it cost me nearly the same amount to simply find (FAR FROM SIMPLE) a running engine and have it put in the car??? Can I 'drop' any of the larger engines into the car without any problems??? ___ next level questions_____ Anyone with any ideas of the causes for a 'big bore' engine to RUN HOT . there is no thermostat connected to the engine and after about an hour of running it starts heading into the red zone. -for direct contact: Rfranklin@price-entities.com -during the day (pacific time), Riccif@cts.com -at night. I would really really appreciate anyones help/response. I'm always greatful to this board and point eveyone I know in its direction. My current 914 was purchase after many hours of discussion on this board and it is a gem. The ENGINE was damaged due to mandatory driving on the face of the MOON in order to get to work for nearly 3 months (streets on my way to work -were pothole infested- caused serious damage to exhaust/engine -though again, according to what I have learned I simply have an 'intake valve -bent/broken' issue). |
Rusty |
Sep 10 2003, 12:09 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,952 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Welcome to the BBS!
1. Yes, you can fit any of the above engines into the car. Make sure you get the entire injection system (including ECU), if you don't have carbs. 2. You're in California. Finding a replacement engine should be easy out your way. There are folks parting out cars all the time. Check the classifieds here and over at Pelican. 3. R&R of an engine is something you can do yourself, if you have a garage or place to work. hope this helps. -Rusty (IMG:style_emoticons/default/smoke.gif) |
Lo-Fi Version | Time is now: 26th September 2024 - 05:29 PM |
