914 -engine sizes- fit/wont fit???, Technical HELLLlpPPP |
Boldylocks |
Sep 10 2003, 11:59 AM
Member Group: Members Posts: 120 Joined: 10-September 03 From: San Diego -CA- Member No.: 1,135 |
First, I'm the owner of a 73 914 with a 1.7 liter engine that has bent/broken intake valves. I'm not a mechanic, but the cost to repair this part seems to be as much, if not more, than finding a running engine and putting it into the car.
With that said: Can I 'drop' any 914 engine into the car??? 1.8 -2.0?? Is the mechanic correct, will it cost me nearly the same amount to simply find (FAR FROM SIMPLE) a running engine and have it put in the car??? Can I 'drop' any of the larger engines into the car without any problems??? ___ next level questions_____ Anyone with any ideas of the causes for a 'big bore' engine to RUN HOT . there is no thermostat connected to the engine and after about an hour of running it starts heading into the red zone. -for direct contact: Rfranklin@price-entities.com -during the day (pacific time), Riccif@cts.com -at night. I would really really appreciate anyones help/response. I'm always greatful to this board and point eveyone I know in its direction. My current 914 was purchase after many hours of discussion on this board and it is a gem. The ENGINE was damaged due to mandatory driving on the face of the MOON in order to get to work for nearly 3 months (streets on my way to work -were pothole infested- caused serious damage to exhaust/engine -though again, according to what I have learned I simply have an 'intake valve -bent/broken' issue). |
tat2dphreak |
Sep 10 2003, 03:21 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
Dude, I would look for a better prospect... if it's running hot and already needed head work, you will start needing a lot more work done soon... and if it was a dropped seat... RUN!
40IDF is too small for 103mm bores. losing the thermostat isn't a big deal... just takes a little longer to get warm without it, which running too cool isn't your trouble anyway! only FI engines(or engines in COLD climates) really need it... can it be fixed... YES! but you are probably going to have to do a real rebuild! if someone used 103mm pistons and didn't know what they were doing... leave the engine where it sits, don't buy someone elses headache. there are a lot of things that could be causing the overheat... it may be nothing, or may be VERY bad....either way, you need to tear the engine apart to find out. |
Lo-Fi Version | Time is now: 26th September 2024 - 05:28 PM |
