914-6 throttle linkage setup/adjustment, Anybody written it up in detail w/ pics? |
campbellcj |
Sep 9 2003, 11:59 PM
I can't Re Member Group: Members Posts: 4,575 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I just swapped-out my pedal cluster for a rebuilt one with a reinforced throttle bellcrank thingie, bronze bushings etc. The clutch and throttle cables are essentially brand new too.
The reason I swapped it is because the throttle-thingie was bent to hell on the old one AND the bushings were shot -- this led to me losing almost an entire day at the track due to inconsistent/sticking accelerator issues (i.e. idle was anywhere from 600rpm to 4K, LOL). It appears the PO decided to install a throttle-stop on the pedal board AFTER the throttle arm thingie on the cluster was already bent to shit. (Yes, I DO have a pedal board and throttle stop on the car.) Anyways...the cluster swapout was no big deal, although DWD did set in a little bit (I found plenty of gook, spare change etc. under there, zinc-sprayed the area, rewired some of the tunnel and dash stuff, etc.) Now it seems like the throttle is kind of maxed-out, i.e. I "loosened" several things to get more length/slack but it still barely hooks up without putting a preload on the carb linkage. The cable adjuster at the pedal end looked pretty normal; didn't fuss with that. I loosened the cable adjuster at the trans bellcrank essentially all the way to the "slack" direction. I also slightly lengthened the trans bellcrank to carb linkage rod-end. So now I'm getting full throttle engagement with what seems like not a lot of pedal travel and the pedalboard stop is virtually all the way out. Is my throttle cable too short for some reason? Or do I just need to basically start over and "equalize" everything again...hence the request for any tips or pics of the procedure. There are so many little adjustable things in this linkage that you get a major chain-reaction when you change one of them. Sorry for the ramble -- I've been working way too much lately and my brain is fried -- hopefully this makes sense somewhat. |
si2t3m |
Sep 11 2003, 07:50 PM
914 addict Group: Members Posts: 346 Joined: 9-January 03 From: Qc, Canada Member No.: 119 |
Thanks for the info. I get the picture now.
I'd say that it's a nice & effective way to bypass the 2 bellcranks and the 2 rods. Actually if i was to do another conversion i'd do something like your setup and it would save 250$ or more for the tranny bellcrank setup. Marc-André |
Lo-Fi Version | Time is now: 5th October 2024 - 06:17 PM |
