joea9146 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None ![]() |
Searched around and found this : But which one is correct ?
Front Rates Torsion Kw (lb/in) Ks (lb/in) Dia (mm) (Wheel) (Spring) 16 77 90 17 97 112 18 122 138 18.5 137 154 19 152 170 20 187 207 21 227 249 22 273 298 23 327 355 ====================================================== > SIZE ( mm) SPRING RATE ( Lb/in) > 18.8 110 > 21 173 > 22 210 > 23 250 > 24 296 > 25 350 |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
Occams razor
actually it doesnt help a bit.. When I buy 600# spring for our 935... Im buying a 600# spring.. Im well aware of spring rates, K values etc.. I know about the ratios that delta "x" will impart to the spring/torsion bar etc.. wheel rate and spring rate are intimately related.. as they will be but one thing in the relationship is constant... the spring rate.. (unless of course it is a spring system made from variable rate springs) |
Lo-Fi Version | Time is now: 25th June 2024 - 12:23 AM |
