type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
i have a d-jet ignition harness i'm cleaning up and it has a 2 foot wire with a spade connector coming out of pin 11 of the 12 pin connector. i'm just curious what the PO did that for. fuel pump connector? hot wired something. harness history is unknown. someone put in a connector for a choke on the Webers? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
Pin 11 on the engine harness (12 pin connector) should be green and it should go to the engine mounted heater blower motor.
The pin 11 on the relay board should connect to the switched contacts of the heater blower relay. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:15 PM |
