type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
i have a d-jet ignition harness i'm cleaning up and it has a 2 foot wire with a spade connector coming out of pin 11 of the 12 pin connector. i'm just curious what the PO did that for. fuel pump connector? hot wired something. harness history is unknown. someone put in a connector for a choke on the Webers? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
type47 |
this ignition harness is for 73-74 as it does not have the connection for the fan at the end of the harness. this wire is something modified by a PO (swap meet harness) so the wire is NOT in the Haynes (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) and is not stock/factory and does not run the heater fan, it is a tap off of the pin 11 to power ..... something. i was just thinking that someone might remember modding a harness for carbs or a connection for key on fuel pump for example and telling what this is for. i'm going to return the harness to as stock a condition as i can and reconnect the jumper wire between pins 11 and 12.
Lo-Fi Version | Time is now: 22nd June 2024 - 09:01 PM |
