wbergtho |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 ![]() |
Here's a few questions for those running 930 stuff on their 914's. I have a 930 front suspension on my car and would like to corner balance it. I have the stock 930 turbo front sway bar with the stock connections at the A-arms (stock rubber bushings). My car is mostly a street car but will see some time on the track. I would like to buy or fabricate adjustable drop links for the front 930 sway bar. Anybody been there and done this? Are parts available or do I need to fab up my own? I can't run the extra whammy top shelf (bulhead next to gas tank set-up) because my V-8 radiator hoses and other junk is in the way.
Also, I'm about ready to pour oil into my 930 LSD gearbox and I'm running an oil cooler & Tilton differential pump. I've been told to turn on the pump and start pouring oil in the side filler hole on the box until it starts to drip out. I have a gallon of Swepco 201 and I'm guessing it may be just enough to satisfy my requirements. Does anyone know what a 930 box oil capacity is w/out cooler accessories?? Do I need a LSD additive along with the Swepco 201? Also, are you guys running trans coolers using a thermo switch to activate the system or a switch on the dash (or both)? So far, I have hooked up a guage and a switch and may also hook up a thermostatically controlled switch. Anyone have part numbers or a source for a good thermo switch? Oh...one more thing...Do you guys run a puke tank from the trans breather? If so, what did you use for a puke tank? I'm just thinking about using a small quart sized tank of some kind? Perhaps smaller? Thanks in advance for all your awesome advice! (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) Bill |
wbergtho |
Just poured a whole gallon of Swepco into my 930 trans and it appears to be thirsty for more. Anyone know how much oil goes in a 930 box?
Lo-Fi Version | Time is now: 28th June 2024 - 12:51 PM |
