914 alginment chicago / rockford, anyone know someone ? |
sk8kat1 |
Mar 16 2006, 01:38 PM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
alright my only guy in rockford that even knows what a 914 is doesn't do alginments (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
so does nyone know who in the chicago area can do one , properly and how far can you drive after doing a turbo tie rod swap can you go with out fuking up the car? |
ArtechnikA |
Mar 17 2006, 12:46 PM
you gotta know what you're getting for your $180.
it's steep for a front only - camber/caster/toe, maybe bumpsteer. it's reasonable for a 4-wheel alignment by someone who knows the cars (and how *not* to strip the trailing arm front link retaining bolts). at that, you'll probably still need your own shims. it's downright cheap for a cornerbalance and 4-wheel alignment. changing your rear damper type to or from gas-charged dampers will probably change that cornerbalance, as will changing springs. changing to the same kind of rear damper won't affect cornerweights. |
Lo-Fi Version | Time is now: 28th June 2024 - 08:37 AM |
