kenpolives |
Member ![]() ![]() Group: Members Posts: 167 Joined: 31-December 03 From: Albany NY Member No.: 1,479 ![]() |
At the point where the acc cable goes through this mount (see pic) it seems that there should be some kind of nut or lock or something to keep the cable fixed at this point. If so, what should be used.
This way it seems like the cable has too much free play. Attached thumbnail(s) ![]() |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,594 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
From your pict, I suspect that you are running carbs. If so, the bracket is too thick. the cable has a threaded end that a M6x1.0 nut can be installed to capture the cable end. But the bracket you have is too thick to allow the threads to come through.
You might make an insert for the bracket with an internal thread of M6x1.0. Make it a t-shaped insert, and put it on from the other side. That would lock the cable down. |
Lo-Fi Version | Time is now: 28th June 2024 - 02:16 PM |
