Removing Trans Drain Plug, Would heat be helpful? |
Tobra |
Mar 22 2006, 11:03 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Gonna take another whack at getting the tight drain plug out of the trans. I know the case and the plug are different metals, and may very well expand at different rates, the question is would it get tighter or looser if I put the heat gun on it?
Jake Raby |
Mar 22 2006, 11:51 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
A 17mm headed bolt welded into a socket works excellent..... Try tapping on the tool with a hammer, while it is inserted into the drain plug before loosening it..
Also, always remove the FILL plug before the drain.. if you don't do this you may end up with a drained gearbox with no possible way of refilling it because the fill plug is seized- there is NOTHING worse than that! (been there, done that!) |
Lo-Fi Version | Time is now: 26th September 2024 - 05:23 PM |
