> transmission oiling and cooling, Once again, my approximation
michel richard
post Mar 25 2006, 08:04 PM
I will be putting significant power through my 901 transmission, with the new engine I am having built (2.5 short stroke twin plug six) and I figured it might be beneficial and fun to build a cooling and oiling system for the tranny.
The factory did it on some racing cars, both 911 and 914. There are pictures on the thread below.
http://www.pbase.com/9146gt/porsche_gearbo...lubrication_kit
As usual, I don't want to go whole hog and through the trouble of sourcing factory parts, so I will machine a system to approximate what the factory did.
This is testing the limits of my abilities, though, and there is no guarantee that I will end up with a system that is good enough to install on my car.
Still, here it goes.
I was looking for a sportomatic oil pump, and Mark Garcia found one in his stash. He was kind enough to send it to me. Here's a thread with those details.
http://www.914world.com/bbs2/index.php?act=...&hl=sporto+pump
The next part I chose to tackle is the tranny drain. Here's what it's supposed to look like:
http://www.pbase.com/9146gt/image/39330791
After much thinking and experimenting, here's what I've come up with (the part is not completed, this is what I've done so far) :
michel richard
post Mar 25 2006, 08:10 PM
I managed to drill 70 holes, 1/16 inch diameter. The area is thus approximately the same as on a 1/2 inch hole. I suspect there's issues of dynamic flow that affect the equivalence (i.e. 64 small holes may not flow as much as 1 big hole, at certain fluid speeds) but this is what I will go with.
The oil lines are not going to be near 1/2 inch id in any event.
Here's a picture of the fitting, as it is now, from the inside.
michel richard   transmission oiling and cooling   Mar 25 2006, 08:04 PM
michel richard   I managed to drill 70 holes, 1/16 inch diameter. ...   Mar 25 2006, 08:10 PM
michel richard   The threaded portion I made by removing the upper ...   Mar 25 2006, 08:12 PM
michel richard   Anyway, details to follow. Once again, I'm not...   Mar 25 2006, 08:14 PM
ArtechnikA   don't forget the Sporto pump transfers engine ...   Mar 26 2006, 08:12 AM
michel richard   The intention is to use he sporto pump to drive th...   Mar 26 2006, 07:43 PM
michel richard   The parts, ready to be brazed.   Mar 26 2006, 07:44 PM
michel richard   And then, brazed and cleaned.   Mar 26 2006, 07:45 PM
michel richard   This is what it will look like from the inside of ...   Mar 26 2006, 07:46 PM
michel richard   On to the next fitting. I got to work on the nozz...   Mar 26 2006, 07:52 PM
michel richard   This let me figure out where to put a hole in the ...   Mar 26 2006, 07:54 PM
michel richard   And here's where the hole ends up on the insid...   Mar 26 2006, 07:55 PM
michel richard   The webbing on the outside of the side cover makes...   Mar 26 2006, 07:57 PM
michel richard   Here it is, pressed in. I cut the fitting a littl...   Mar 26 2006, 07:58 PM
michel richard   And here's the progress so far.   Mar 26 2006, 08:02 PM
john rogers   The system looks good so far. I started running a ...   Mar 26 2006, 08:13 PM
ArtechnikA
- Lo-Fi Version Time is now: 9th January 2025 - 05:21 AM
