Rebuilding the FI relay board. |
Air_Cooled_Nut |
Sep 15 2003, 04:22 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
My soldering skills leave something to be desired and the space in which to perform the soldering is rather tight but I was able to do it...I think...at least it looked okay and felt solid. Here's a picture of before my soldering and after it was all coated:
(IMG:http://www.914world.com/bbs2/uploads/post-2-1063733351.jpg) Mine showed only a couple cracks in the tar bottom and I'm sure I could've easily patched them but I wanted to see if recoating was easy. It is, just messy and I recommend wearing nitrile or latex gloves. The LET shrinks considerably. One container will be more than enough for two coats and left overs for later wiring projects. The 3M undercoating sprayed on easily and did not shrink. Several coats of that would probably be fine. I hesitated using RTV because I thought I read somewhere that it may be slightly acidic on some metals and I didn't want to risk having my copper strips and soldered joints disappearing on me one day while driving. If anyone else has done this differently I would like to hear about it, be is successful or not. Mine was successful (short term at least (IMG:style_emoticons/default/wink.gif) ) as the car started right up and ran after installation. Will it last for the years to come? We'll certainly find out (IMG:style_emoticons/default/beerchug.gif) |
mightyohm |
Sep 15 2003, 09:53 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
I used Silicone Conformal Coating. It's very thin and clear so you can still see what's going on underneath, but it should keep moisture and most chemicals out. It should also be a lot easier to remove than that black stuff.
Tony, even if you make a custom PCB you still have those funky connectors to the wiring harnesses. Probably easier just to use the real deal. If you really wanted to you could probably open up all your old relays and rebuild them by putting new (smaller) relays inside. Those things are way too expensive new. |
Lo-Fi Version | Time is now: 26th December 2024 - 06:28 PM |
