> Second drive (trouble), I have 40 miles to go..
redshift
post Sep 15 2003, 07:47 PM
Bless the Hell out of you!
Ok, second drive started off fine, oil light no flicker when she's cooled off..
Sounds:
1. Lean
2. Over Advanced
How many clicks off of black smoke is your mixture set @?
It feels now like it wants to be shifted just under the power curve, and it pings in a 200 rpm range starting at 3k.
Maybe I can string together an a/f meter from paperclips, and dustmites?
I hope the oil flicker isn't bad bearings... (IMG:style_emoticons/default/blink.gif)
62 miles isn't better than 4800..
M
Eric Taylor
post Sep 15 2003, 11:15 PM
Geoff what does someone need to test the MPS? Also your saying the MPS of my 2.0 djet would not work on my 1.7?
Eric
redshift   Second drive (trouble)   Sep 15 2003, 07:47 PM
Tom Perso   Sounds like timing problems. You need to check th...   Sep 15 2003, 08:41 PM
Tom Perso   I've never run FI, so I can't help your ot...   Sep 15 2003, 08:41 PM
Bleyseng   Yes, use a timing light and set the timing to 27 d...   Sep 15 2003, 08:57 PM
redshift   Misunderstood.. I wanted to get a general consens...   Sep 15 2003, 09:50 PM
Bleyseng   I am running the idle adjustment screw on the ECU ...   Sep 15 2003, 10:11 PM
redshift   I feel even better then, that is just about where ...   Sep 15 2003, 10:17 PM
Bleyseng   The question is why are the plugs fouling?   Sep 15 2003, 10:22 PM
redshift   ...   Sep 15 2003, 10:36 PM
Bleyseng   Does the MPS hold a 15hg vacuum for about 5 minut...   Sep 15 2003, 10:39 PM
redshift   Let me clear up the ends I left hanging: motor we...   Sep 15 2003, 10:50 PM
Bleyseng   At 2000 rpms you should not be running in the idle...   Sep 15 2003, 11:02 PM
Eric Taylor   Geoff what does someone need to test the MPS? Also...   Sep 15 2003, 11:15 PM
Bleyseng   Sure it will work but rich. The MPS's were ca...   Sep 15 2003, 11:25 PM
Bleyseng   Test with one of these.   Sep 15 2003, 11:31 PM
Eric Taylor   Thanks geoff! If my MPS is bad, where can a ge...   Sep 15 2003, 11:47 PM
Bleyseng   Pelican sells a 043 for 74-76 2.0L for $725 ...   Sep 15 2003, 11:59 PM
Jeff Bonanno   just got a rebuilt unit from a pp member on ebay. ...   Sep 16 2003, 12:01 AM
Bleyseng   That is the key to a good MPS. Does it hold a vacu...   Sep 16 2003, 12:05 AM
rhodyguy   you're the man geoff. this should be a nailed ...   Sep 16 2003, 05:33 AM
redshift   Hey Geoff, MPS is the right one, and it's been...   Sep 16 2003, 06:51 AM
Bleyseng   Baaad sign if its been opened. Test it will a vacu...   Sep 16 2003, 09:19 AM
mike_the_man   Geoff, I adjusted both of my MPS's and I didn...   Sep 16 2003, 09:37 AM
porsche735   There are many things that can effect teh engine i...   Sep 16 2003, 09:49 AM
Bleyseng   If you used Brad Anders methods with a Wavetek or ...   Sep 16 2003, 09:51 AM
Bleyseng   A shorted or dead CHT results in a rich mix when s...   Sep 16 2003, 09:56 AM
redshift   MPS checked out fine, I gave my mechanic your link...   Sep 16 2003, 02:03 PM
redshift   The valves were tight, way tight, real tight, supe...   Sep 16 2003, 02:40 PM
-P-   ...   Sep 16 2003, 04:24 PM
Bleyseng   Almost any auto mechanic will have a simple vacuum...   Sep 16 2003, 04:29 PM
- Lo-Fi Version Time is now: 15th January 2025 - 11:34 AM
