> Second drive (trouble), I have 40 miles to go..
redshift
post Sep 15 2003, 07:47 PM
Bless the Hell out of you!
Ok, second drive started off fine, oil light no flicker when she's cooled off..
Sounds:
1. Lean
2. Over Advanced
How many clicks off of black smoke is your mixture set @?
It feels now like it wants to be shifted just under the power curve, and it pings in a 200 rpm range starting at 3k.
Maybe I can string together an a/f meter from paperclips, and dustmites?
I hope the oil flicker isn't bad bearings... (IMG:style_emoticons/default/blink.gif)
62 miles isn't better than 4800..
M
redshift
post Sep 16 2003, 06:51 AM
Hey Geoff, MPS is the right one, and it's been -opened-..
(all over the phone)
M
redshift   Second drive (trouble)   Sep 15 2003, 07:47 PM
Tom Perso   Sounds like timing problems. You need to check th...   Sep 15 2003, 08:41 PM
Tom Perso   I've never run FI, so I can't help your ot...   Sep 15 2003, 08:41 PM
Bleyseng   Yes, use a timing light and set the timing to 27 d...   Sep 15 2003, 08:57 PM
redshift   Misunderstood.. I wanted to get a general consens...   Sep 15 2003, 09:50 PM
Bleyseng   I am running the idle adjustment screw on the ECU ...   Sep 15 2003, 10:11 PM
redshift   I feel even better then, that is just about where ...   Sep 15 2003, 10:17 PM
Bleyseng   The question is why are the plugs fouling?   Sep 15 2003, 10:22 PM
redshift   ...   Sep 15 2003, 10:36 PM
Bleyseng   Does the MPS hold a 15hg vacuum for about 5 minut...   Sep 15 2003, 10:39 PM
redshift   Let me clear up the ends I left hanging: motor we...   Sep 15 2003, 10:50 PM
Bleyseng   At 2000 rpms you should not be running in the idle...   Sep 15 2003, 11:02 PM
Eric Taylor   Geoff what does someone need to test the MPS? Also...   Sep 15 2003, 11:15 PM
Bleyseng   Sure it will work but rich. The MPS's were ca...   Sep 15 2003, 11:25 PM
Bleyseng   Test with one of these.   Sep 15 2003, 11:31 PM
Eric Taylor   Thanks geoff! If my MPS is bad, where can a ge...   Sep 15 2003, 11:47 PM
Bleyseng   Pelican sells a 043 for 74-76 2.0L for $725 ...   Sep 15 2003, 11:59 PM
Jeff Bonanno   just got a rebuilt unit from a pp member on ebay. ...   Sep 16 2003, 12:01 AM
Bleyseng   That is the key to a good MPS. Does it hold a vacu...   Sep 16 2003, 12:05 AM
rhodyguy   you're the man geoff. this should be a nailed ...   Sep 16 2003, 05:33 AM
redshift   Hey Geoff, MPS is the right one, and it's been...   Sep 16 2003, 06:51 AM
Bleyseng   Baaad sign if its been opened. Test it will a vacu...   Sep 16 2003, 09:19 AM
mike_the_man   Geoff, I adjusted both of my MPS's and I didn...   Sep 16 2003, 09:37 AM
porsche735   There are many things that can effect teh engine i...   Sep 16 2003, 09:49 AM
Bleyseng   If you used Brad Anders methods with a Wavetek or ...   Sep 16 2003, 09:51 AM
Bleyseng   A shorted or dead CHT results in a rich mix when s...   Sep 16 2003, 09:56 AM
redshift   MPS checked out fine, I gave my mechanic your link...   Sep 16 2003, 02:03 PM
redshift   The valves were tight, way tight, real tight, supe...   Sep 16 2003, 02:40 PM
-P-   ...   Sep 16 2003, 04:24 PM
Bleyseng   Almost any auto mechanic will have a simple vacuum...   Sep 16 2003, 04:29 PM
27 User(s) are reading this topic (27 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 12:02 PM
