Rear suspension problem, Ain't Right |
JJ914 |
Mar 26 2006, 04:02 PM
Big JJ Group: Members Posts: 90 Joined: 30-December 04 From: Augusta GA Member No.: 3,374 Region Association: None |
Hey here is my problem. The left rear ride height is about one inch lower than the right( 24 right- 23 left). The rest of the problem is that the left rear wheel is cambered in. I put a level on the right wheel and it is straight vertically but the left is quite pitched in. I have already changed the springs and no change. Could an alignment fix this problem. And before you ask there is no rust in the consoles. can the rear ride height be adjusted, that would fix one problem. I have seen the wedge shape shimes for the rear. Also the top of the left tire is very near the fender and the right has a normal gap. I dont know where to go next. HELP!!!
r_towle |
Mar 27 2006, 07:27 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Add shims, less camber.
They are available in the resources section of this site. The rear can be adjusted. Ride height Caster/Camber toe in/toe out Rich |
Lo-Fi Version | Time is now: 26th September 2024 - 05:20 PM |
