Rear suspension problem, Ain't Right |
JJ914 |
Mar 26 2006, 04:02 PM
Big JJ Group: Members Posts: 90 Joined: 30-December 04 From: Augusta GA Member No.: 3,374 Region Association: None |
Hey here is my problem. The left rear ride height is about one inch lower than the right( 24 right- 23 left). The rest of the problem is that the left rear wheel is cambered in. I put a level on the right wheel and it is straight vertically but the left is quite pitched in. I have already changed the springs and no change. Could an alignment fix this problem. And before you ask there is no rust in the consoles. can the rear ride height be adjusted, that would fix one problem. I have seen the wedge shape shimes for the rear. Also the top of the left tire is very near the fender and the right has a normal gap. I dont know where to go next. HELP!!!
jdogg |
Mar 28 2006, 07:19 AM
Member Group: Members Posts: 431 Joined: 28-January 03 From: Youngsville, NC Member No.: 204 |
Jason-
This might be quite a ride for you, but there is a guy in Durham that I take my car to for alignments. He is a suspension shop that caters mostly to Porsches. He has had several 914s, so knows these cars well. It may be worth your ride up to see him, he also has a set of scales so you can have him corner balance it as well. The name of the shop is "Digital Chassis" and his name is Brad Moyer.....(919)384-7070. He is real busy, so you may need to call him more than once. |
Lo-Fi Version | Time is now: 26th September 2024 - 05:20 PM |
