Making the a-arms "wider"...besides camber issues,, what other "gotchas" will I hit?? |
Mueller |
Jul 13 2005, 08:24 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Trying to figure out if I can safely go 1" per side to make the front track the same as the rear....I currently have 1.25" thick spacers, so I could eliminate those which would be nice.
I figure not that big of a deal on the camber since that is easily fixed by opening up the top of the shock tower (salvage title car, so no worries about "ruining it" (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ) For those that have installed turbo-tie rods, do you think there is enough adjustment to move the ends out an inch per side??? Attached image(s) |
Mueller |
Mar 28 2006, 12:35 PM
the second modification to the steering rack will be just as "fun" to perform (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif)
you'd need a "sacrificial" rack so that the ends can be cut off, machined and installed to a good rack....this will cure the problem of the turbo tie rods being too short.... Attached image(s) |
Lo-Fi Version | Time is now: 6th January 2025 - 07:10 PM |
