> Making the a-arms "wider"...besides camber issues,, what other "gotchas" will I hit??
Mueller
post Jul 13 2005, 08:24 PM
914 Freak!
Trying to figure out if I can safely go 1" per side to make the front track the same as the rear....I currently have 1.25" thick spacers, so I could eliminate those which would be nice.
I figure not that big of a deal on the camber since that is easily fixed by opening up the top of the shock tower
(salvage title car, so no worries about "ruining it" (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) )
For those that have installed turbo-tie rods, do you think there is enough adjustment to move the ends out an inch per side???
groot
post Mar 28 2006, 12:45 PM
Dis member
And... when I made my camber plates I actually had to use them to reduce camber... like you're suggesting.
Mueller   Making the a-arms "wider"...besides camber issues,   Jul 13 2005, 08:24 PM
TimT   hehehe, some of "F troop" try and make the A-arm ...   Jul 13 2005, 08:37 PM
bondo   Here's a gotcha.. different (lower) effective ...   Jul 13 2005, 08:39 PM
Mueller     Jul 13 2005, 08:39 PM
Mueller     Jul 13 2005, 08:40 PM
bondo   What if you widened the crossmember and moved the ...   Jul 13 2005, 08:44 PM
MattR   wider is better http://www.914world...   Jul 13 2005, 08:47 PM
Mueller     Jul 13 2005, 08:48 PM
Howard R   Mike, You can certainly 19mm without any problems...   Jul 13 2005, 09:42 PM
Brett W   When you lengthen the arms you need to make sure t...   Jul 13 2005, 09:48 PM
john rogers   I use 1 inch spacers in the front and 1 1/4 spacer...   Jul 13 2005, 10:32 PM
Britain Smith   There is a guy on the Pelican board that had this ...   Jul 13 2005, 10:44 PM
McMark   <...   Jul 14 2005, 01:08 AM
ArtechnikA     Jul 14 2005, 06:21 AM
redshift   http://www.914world.com/bbs2/ht...   Mar 28 2006, 12:32 PM
Mueller   the second modification to the steering rack will ...   Mar 28 2006, 12:35 PM
turbo914v8   How wide do you want to go? = How deep is your poc...   Mar 28 2006, 12:39 PM
groot   Wider is better, as you know. I've done it (by...   Mar 28 2006, 12:43 PM
groot   And... when I made my camber plates I actually had...   Mar 28 2006, 12:45 PM
Mueller     Mar 28 2006, 12:49 PM
groot   You have a welder, right? They can be lengthened ...   Mar 28 2006, 12:49 PM
Mueller     Mar 28 2006, 01:08 PM
groot   Do it!!!! It'll make you feel ...   Mar 28 2006, 01:55 PM
Mueller     Mar 28 2006, 03:25 PM
Mueller   <...   Mar 28 2006, 04:52 PM
J P Stein   I've stared at this till I'm blue in the f...   Mar 28 2006, 06:56 PM
Mueller   <...   Mar 28 2006, 09:01 PM
Mueller     Mar 28 2006, 09:03 PM
Porcharu     Mar 29 2006, 01:50 AM
groot   As I understand scrub radius, it increases the mom...   Mar 29 2006, 06:30 AM
Brett W   Scrub radius is bad. This is one of the major pro...   Mar 29 2006, 07:50 AM
Bigbohr   This is what a 964/993 front looks like: the strut...   Mar 29 2006, 08:08 AM
J P Stein   Positive scrub radius doesn't seem to be a hug...   Mar 29 2006, 08:19 AM
J P Stein   <...   Mar 29 2006, 08:20 AM
groot   Ummmm, drugs are bad, umkay. http...   Mar 29 2006, 12:00 PM
J P Stein   OK, here's the way I see the problem...no pics...   Mar 29 2006, 07:33 PM
groot   JP, good illustration (figuratively). I agree with...   Mar 30 2006, 07:00 AM
J P Stein     Mar 30 2006, 08:56 AM
andys   Your increased scrub radius accentuates the change...   Mar 30 2006, 11:12 AM
Cloudbuster     Mar 30 2006, 12:01 PM
Mueller   pics for JP.....'91 C2 (sorry for being so dir...   Apr 3 2006, 12:08 PM
Mueller   red arrows show pivot points....mono-ball replacem...   Apr 3 2006, 12:09 PM
J P Stein   need a pic looking fwd or aft.....like Groot's...   Apr 3 2006, 12:57 PM
- Lo-Fi Version Time is now: 6th January 2025 - 06:56 PM
