> Making the a-arms "wider"...besides camber issues,, what other "gotchas" will I hit??
Mueller
post Jul 13 2005, 08:24 PM
914 Freak!
Trying to figure out if I can safely go 1" per side to make the front track the same as the rear....I currently have 1.25" thick spacers, so I could eliminate those which would be nice.
I figure not that big of a deal on the camber since that is easily fixed by opening up the top of the shock tower
(salvage title car, so no worries about "ruining it" (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) )
For those that have installed turbo-tie rods, do you think there is enough adjustment to move the ends out an inch per side???
Porcharu
post Mar 28 2006, 10:52 PM
QUOTE (J P Stein @ Mar 28 2006, 04:56 PM)
If you move out the bottom an inch or 2 & not the top, you can (or will) 10 deg negative camber (or so) unless you change the angle of incidence twixt the strut & axle.....and even that would gain you a bit more that half your movement of the lower arm.
The strut housing would be at a greater angle(to the earth) & side load the hell out of it. I gots those problems now.
That would be BAD. Ever drive a late model Mustang? - those cars use a strut with about 20 degrees of kingpin angle. That is the main reason those cars handle like pigs, if you "adjust" the spindle back to 10 degrees or so the car handles very well even with the horrible front weight bias.
Mueller   Making the a-arms "wider"...besides camber issues,   Jul 13 2005, 08:24 PM
TimT   hehehe, some of "F troop" try and make the A-arm ...   Jul 13 2005, 08:37 PM
bondo   Here's a gotcha.. different (lower) effective ...   Jul 13 2005, 08:39 PM
Mueller     Jul 13 2005, 08:39 PM
Mueller     Jul 13 2005, 08:40 PM
bondo   What if you widened the crossmember and moved the ...   Jul 13 2005, 08:44 PM
MattR   wider is better http://www.914world...   Jul 13 2005, 08:47 PM
Mueller     Jul 13 2005, 08:48 PM
Howard R   Mike, You can certainly 19mm without any problems...   Jul 13 2005, 09:42 PM
Brett W   When you lengthen the arms you need to make sure t...   Jul 13 2005, 09:48 PM
john rogers   I use 1 inch spacers in the front and 1 1/4 spacer...   Jul 13 2005, 10:32 PM
Britain Smith   There is a guy on the Pelican board that had this ...   Jul 13 2005, 10:44 PM
McMark   <...   Jul 14 2005, 01:08 AM
ArtechnikA     Jul 14 2005, 06:21 AM
redshift   http://www.914world.com/bbs2/ht...   Mar 28 2006, 12:32 PM
Mueller   the second modification to the steering rack will ...   Mar 28 2006, 12:35 PM
turbo914v8   How wide do you want to go? = How deep is your poc...   Mar 28 2006, 12:39 PM
groot   Wider is better, as you know. I've done it (by...   Mar 28 2006, 12:43 PM
groot   And... when I made my camber plates I actually had...   Mar 28 2006, 12:45 PM
Mueller     Mar 28 2006, 12:49 PM
groot   You have a welder, right? They can be lengthened ...   Mar 28 2006, 12:49 PM
Mueller     Mar 28 2006, 01:08 PM
groot   Do it!!!! It'll make you feel ...   Mar 28 2006, 01:55 PM
Mueller     Mar 28 2006, 03:25 PM
Mueller   <...   Mar 28 2006, 04:52 PM
J P Stein   I've stared at this till I'm blue in the f...   Mar 28 2006, 06:56 PM
Mueller   <...   Mar 28 2006, 09:01 PM
Mueller     Mar 28 2006, 09:03 PM
Porcharu     Mar 29 2006, 01:50 AM
groot   As I understand scrub radius, it increases the mom...   Mar 29 2006, 06:30 AM
Brett W   Scrub radius is bad. This is one of the major pro...   Mar 29 2006, 07:50 AM
Bigbohr   This is what a 964/993 front looks like: the strut...   Mar 29 2006, 08:08 AM
J P Stein   Positive scrub radius doesn't seem to be a hug...   Mar 29 2006, 08:19 AM
J P Stein   <...   Mar 29 2006, 08:20 AM
groot   Ummmm, drugs are bad, umkay. http...   Mar 29 2006, 12:00 PM
J P Stein   OK, here's the way I see the problem...no pics...   Mar 29 2006, 07:33 PM
groot   JP, good illustration (figuratively). I agree with...   Mar 30 2006, 07:00 AM
J P Stein     Mar 30 2006, 08:56 AM
andys   Your increased scrub radius accentuates the change...   Mar 30 2006, 11:12 AM
Cloudbuster     Mar 30 2006, 12:01 PM
Mueller   pics for JP.....'91 C2 (sorry for being so dir...   Apr 3 2006, 12:08 PM
Mueller   red arrows show pivot points....mono-ball replacem...   Apr 3 2006, 12:09 PM
J P Stein   need a pic looking fwd or aft.....like Groot's...   Apr 3 2006, 12:57 PM
- Lo-Fi Version Time is now: 6th January 2025 - 06:56 PM
