Oil Lines, which to use? |
porsche735 |
Sep 15 2003, 06:00 PM
Member Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 |
OK, so I am finally going to run a front mounted oil cooler. From what I have read -12 AN is the way to go for the lines. However, there are 2 choices.
Aeroquip steel braided hose at $6.55 a foot Aeroquip socketless hose at $4.96 a foot Seems like I will need about 28 feet (sounds like a lot) from what I have read. So cost difference is $44.52. The connectors are more expensive too $88.18 for the socketless versus $126.52 for the reuseable. There is another $38.34. Total $82.86 difference. It seems that given the routing that there is not much abrasion (http://www.914world.com/bbs2/index.php?act=ST&f=2&t=4657). Is the steel braided really needed? (IMG:style_emoticons/default/confused24.gif) Wadya think? Chris |
ArtechnikA |
Sep 16 2003, 03:03 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(porsche735 @ Sep 16 2003, 12:53 PM) Fluidyne 30618 (21"x5.88"x3") $321 (what are the "extra" AN-6 and 3/8" NPT for?) I still can't find a site with the Earl's cooler!!! What are your thoughts on steel braided versus regular hose? try here Earl's Website for Earl's. no pricing AFAIK, i go to Summit for Earl's stuff, they have the big books with pricing... my guess on the FluidDyne 'extra' fittings is the drain at the cooler itself; a nice feature. i prefer the braided steel hose but lots of guys have reported good results with blue high-pressure hydraulic-equipment hose. on the line from the tank to the oil pump run an anti-collapse internal spring if possible - evidently it's possible for the pump to pull quite a vacuum on that line. IAC it'd be bad to have the hose liner collapse. look at the Earl's application information for pressure ratings and such - they make a wide variety of hose types for a reason. there's always a tradeoff on performance vs weight vs cost. and even thr braided steel stuff does NOT last forever - or more accurately - the neoprene doesn't - especially in the ozone-laden desert southwest. i had some fuel hose spring leaks like a garden soaker hose - i'm sure the fuel oxygenates don't help this situation ... |
Lo-Fi Version | Time is now: 15th January 2025 - 07:42 AM |
