Understeer?, Woah... tha's wierd... |
Brando |
Mar 30 2006, 04:04 AM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
So, I've been driving the 914 alot more lately (side story to that). And I've noticed since my last alignment that the car seems to have a bit of understeer*
* To clarify, am I correct in saying under-steer is when you turn the steering wheel and the car does not immediately turn (plows a bit)? So, here's what I got: Boges all around. 23mm Adjustable bar up front. Stock rear bar. Stock tortion bars up front. 120lb springs in back. Rear ride hieght is 5½" from ground to rockers. Front ride height is 4½" from ground to rockers. I do not have money to throw at a solution. I very much would like to keep the rear bar as it does keep the car very stable in wide wide WIDE turns that I like to take very fast. I guess I'm asking, how should I adjust this? Stiffen the front bar? Run it "softer"? Level the car out front and rear? I do not have adjustable perches in the back (consider it stock hardware). New shocks are not an option. When I was running with the front bar alone, I noticed the front of car would stay flat in very tight turns but would plow a little bit -- give it enough gas and it would straighten the ass-end out in the direction I want, when I added the rear bar it made the whole car stay level in turns, but the understeer* remained, was a bit more noticeable. Any suggestions, please fire away. Thanks. I know I'm crazy, but I can't spare any pennies on my cars for some time. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
SirAndy |
Mar 30 2006, 04:14 AM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
if you can, back off the front bar a bit, make it "softer" ... that means moving the adjuster towards the front of the car ...
also, 4 1/2" in the front seems pretty damm low to me, depending where exactly you measured. could be that you're running out of shock travel on hard cornering, which is no gud ... you got the bump-steer spacers installed? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
Lo-Fi Version | Time is now: 27th December 2024 - 06:21 AM |
