Type 4 Engine build basics, Best approach on rebuild options |
TomL |
Mar 30 2006, 05:15 PM
Newbie Group: Members Posts: 13 Joined: 10-October 04 From: Lubbock, TX Member No.: 2,916 |
I am hoping to build a good, solid, higher performance Type 4 which will be used as a daily driver, touring car and perhaps an occasional AX. I have some questions.
1. Are all type 4 engine cases identical? If so, why are "GA" cases preferable? 2. What practical difference is there between a 78.4 stroke crank and an 80mm crank--since the 80mm seems to be more prevalent and a little less expensive? 3. Which is the most preferable bore--94mm, 96mm or 103/4mm? 4. Is there any practical difference between standard 2.0 sized crank journals and chevy sized? 5. Can 1.8 heads be "massaged" enough for decent performance? 6. Pure speculation--What kind of HP might I expect out of an engine with: 80mm stroke, 96mm bore, a moderate cam, re-worked 1.8 heads (8.5 or 9:1CR) and carbs? Thanks for any answers you can give TomL |
cnavarro |
Mar 30 2006, 05:59 PM
Cylinder Guru Group: Members Posts: 472 Joined: 30-December 02 From: Chicagoland! Member No.: 49 Region Association: None |
What kind of budget do you have set aside? That will dictate how things progress and what kind of horsepower you can expect.
Lo-Fi Version | Time is now: 24th September 2024 - 01:11 PM |
