Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
when you remove the enrichment chokes on an IDF, and use blockoff plates, do you pull the 2 "piston" shaped things from inside that cavity?
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Left plunger thingys onmy 40IDF's put the block off plates on works good as the plungers are spring loaded to stay in the normal running position. can't lose the parts this way either or forget how it supposed to go back together.
Warm up ??? hell it's already warm down here. |
Lo-Fi Version | Time is now: 24th June 2024 - 11:47 PM |
