Brian Mifsud |
Mechanical Engineer ![]() ![]() ![]() Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None ![]() |
aren't the 914 struts identical to the pre-SC struts minus the 5 lug hubs? Are wheel bearing identical? Can I just switch the hubs (front only).
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
QUOTE(Dr Evil @ Mar 31 2006, 11:11 PM) (IMG:style_emoticons/default/WTF.gif) Wow, I have never seen that before. Is it realy more economical than just swapping the whole front end ? You would still need breaks and such. Still neat, though. it's a fairly common mod for the VW bug crowd...I see nothing wrong with it if done correctly....if you are paying someone for the parts, then yes, I could see the cost being the same or more... one benifit is that you don't have to replace as many parts...many people feel more comfortable just replacing calipers and a wheel hub than having to remove a complete strut or a-arm assembly (and then have to get a wheel alignment) |
Lo-Fi Version | Time is now: 25th June 2024 - 12:24 AM |
